After Boolean union of parts in "part studio" the Drawing and assmbly wont update
I Made a part in the part studio, then created a drawing and an assmbly of the part.
Then i added some extra features to the part and Boolean union joined the parts. after that the drawings would not update.
Would love some help on this please.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    Selection order in the Boolean feature is important. Make sure you select the part that was originally in the drawing first, then select the other parts. That way the original Part ID is maintained.
  • david_hay210david_hay210 Member Posts: 4
    Amazing thanks Neil. That has solved my Issue.
