How to create parametric dimensions?
I come from Alibre / Geomagic Design which collects each given dimension into parameter list. Parameter list is accessible when adding new dimensions so it's easy to create parametric designs without even thinking through what parameters/variables are you going to use. I couldn't think of better way to handle parameters.
Is there a way to access given dimensions in OS? How do you create parametric designs?
For example, I wan't to create hole with same diameter to sketch 2 as I made to sketch 1 (and it should follow changes too). Then I wan't dimension from egde to be [dimension from sketch1]+64. Then I wan't pattern with step 32mm as many as fit's to the extrude (follow changes on the size of extrude). Is this currently possible?
3
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,144 PRO
No, but this is what I want too. You can only link ATM with sketcher constraints.5 -
3dcad Member, OS Professional, Mentor Posts: 2,476 PRO
How is this made in solid works? I think Alibre got it right with automatically creating a variable of each given dimension, count or such and you can later rename or create new parameters and equations are supported of course.. Some cads need to first create a variable and then you can use it as dimension - I'm way too busy/lazy to pre-think names and values for variables before modeling..
And if parametric dimensions are still in todo list, I hope the framework is Global Parameters from the beginning.. Meaning that parameters can be accessed from different part studios, assemblies, documents, users, world and the universe!//rami0
-Jim
I see that this thread is dated mid-2015. We are almost mid-2017, and given the speed OnShape is developing, I was wondering if meanwhile there is a way for creating parametric dimensions.
If there is none, just a "no" reply will help. At least i will stop searching...
Many thanks
