How to hide parts from part studio in a drawing
brandon_nason
Member Posts: 7 ✭✭
I have a shed design that I am trying to create a drawing for. I want a view directly from the front, however since I haven't modeled the door/windows, you can see the framing of the back wall. I want to hide that only on that page, is this possible? You can see the drawing on page 2 here: https://cad.onshape.com/documents/403bf945288225ad8202767d/w/d9f17939af4058f32feca9e3/e/40309454299bc62f48aa93af
You could also manually hide the parts of the back wall in the drawing view.
You could also add a "dummy" surface inside that hides the back (and covers all the openings on the front), or just basic "plugs" for the windows.
You could also use a section view (with a right or left view off to the side of the drawing sheet).
