Please publish your high-quality custom features!
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,253
In the release last November, we added the ability to "publish" versions with custom features (https://forum.onshape.com/discussion/22395/improvements-to-onshape-november-28th-2023/p1#featurescript). Our goal was to make it easier to find the "authoritative" version of a custom feature, rather than just "Copy of Spur Gear", by elevating published features higher in the public search rankings and making it possible to search for them explicitly. But for the plan to work, we rely on FeatureScript authors to judiciously use this "publish" functionality.
The rule I would suggest is: if a feature is good enough for you to write a forum post about, you should also publish it in the product.
Internally, we at Onshape have published many of the custom features we've developed (that have not been obsoleted by built-in functionality since) and a number of our users have published their custom features as well. But there are a number of popular, high-quality custom features that have not been published and I would encourage the authors to do that. The list below is not meant to be exhaustive, just some popular custom features that I think should be published:
@antlu65
https://cad.onshape.com/documents/5c0528b62c1fbb13a2a0e739/v/f86229e7f586f8517a2068a9/e/7cbb452d4d5e963a034ce616
@dave_cowden
https://cad.onshape.com/documents/6b640a407d78066bd5e41c7a/v/845d049782179b9faee8b6e6/e/197ed76423f98702e0d8e7db
https://cad.onshape.com/documents/2d7e0a6b68c2039da4221ebc/v/380dd981eb12974a5280b8eb/e/b92e2707bc8e8165e208a55e
https://cad.onshape.com/documents/cfec40e2b66bb4ddb2f3414b/v/3f1bcca2812d650a51c9960d/e/1ac9d45620418b8d1e3154f5
https://cad.onshape.com/documents/0de04acb5bac92ca16796edf/v/685026de2603b19fd2c6003d/e/680f0565e919e6e39a06f4df
@Evan_Reese
https://cad.onshape.com/documents/28ce556560feca48059476f9/v/00d5dea652480e57966bd42d/e/56708624b09fbbd5f0398d78
https://cad.onshape.com/documents/309e817bcaf616677a834985/v/2a5b0d5c7243e2a8e6a93479/e/76d8abc457676e82f84a3ece
https://cad.onshape.com/documents/f4d470584fdeef9603415532/v/7d0c0b30a8b73bbd6ed13b01/e/acddbbed81af3772a07adf21
https://cad.onshape.com/documents/d997b0ffc30f659113b10c00/v/a9e4f209775174dbb9f2b5fa/e/a59f52547080e509330b02f7
https://cad.onshape.com/documents/cd51f29c6937305f86a9df95/v/f84a5282d4d42e13b923e492/e/44de484ba0acba52f99fcfc5
@robert_morris
https://cad.onshape.com/documents/2972a375d9fd3b741d7cc02a/v/02335aee238a71f9c1b0b383/e/403280a8c811319478bddf50
@MBartlett21
https://cad.onshape.com/documents/3ca261a95938af152088fca8/v/2c155879c31e3f9495b86759/e/82151ac6fb25c86ba23d7f85
https://cad.onshape.com/documents/84d939daceef6a928b8abcba/v/cc61d2dc258bf444bbef75a5/e/3f830335f32af139a2f26b8f
@darren_13
https://cad.onshape.com/documents/4bf18c75321ea2c8c2ea770d/v/bd6d5eed825fa5757b52e03e/e/b319e7a87bba701e3e02a0fa
@Alex_Kempen
https://cad.onshape.com/documents/9cffa92db8b62219498f89af/v/d1389fa34235160533671706/e/99672d1e329b38e647d90146
Thanks and happy CADding!
@antlu65
@dave_cowden
@Evan_Reese
@robert_morris
@MBartlett21
@darren_13
@Alex_Kempen
10
I got busy and forgot about publishing the mounting boss feature.
It is published now.
I'm creating custom tables in my Wires feature and Freeform Spline feature, which gives a warning I've been ignoring about it impacting performance, because I like that the table is just there for anyone using the feature (am I right to think that people would need to also add the table otherwise?). I can't publish those features since this is flagged as an error. Thoughts on the best solution? Should I just move the tables to another Feature Studio?
I'm also finding the pdf requirement a hinderance for some I've made. I know the real solution is to make a pdf, but my time is constrained such that I probably won't get to that, and I'd like to publish them anyway. I understand that the pdf requirement is meant to act as a filter for quality and completeness though, so maybe I'm just proving that it's working.
On the geometry.fs warning, the thing to do is to remove the geometry.fs import and replace it with imports of specific modules actually needed. For example, in freeform spline, you just need
On the pdf requirement, the perfect is the enemy of the good -- at minimum just have some text explaining what the purpose of the feature is and any caveats -- it doesn't have to be pretty.
Thanks!
Hex Rod will draw a 1/2" hex rod between two parallel mate connectors. It allows offsets at the start and end, a rotation angle, and naming.
I'm not a programmer, so it took me half a day of struggle, but it's an accomplishment!
https://cad.onshape.com/documents/68cc6e7f44c7d45ead2a1b38/w/5c67626b11109a69231f9606/e/f5a54e138097299817bb6f7b
https://www.onshape.com/en/features/custom-features
In general, it took me too long to 1) find the template and 2) find out where to set the `Feature Type Description` (see below screenshot for where I ultimately had to stick it in order to publish).
I applaud the pursuit of high quality entires, and I think this is the right approach. That being said, please, please, please don't just give me a failure message when I try to publish, make sure that there is a useful link to how to resolve the problem! Having high quality publishing instructions will result in high quality outputs. Esp. re the PDF, where making it easy to find the suggested template will result in lots of us using it.
Hi all. Can anyone please let me know what this error message means and how to resolve? I have added descriptions in six specific different locations and non have worked. Thank you.
I think it's the feature description itself here
