Individual part spin with the Mouse
stuart_moritastuart_morita Member Posts: 2 PRO
Moving from Solidworks to Onshape, and I changed my preferences for the mouse to "Solidworks".  In SWX when you have multiple parts in an assembly, I can spin all the parts together with the middle button.  If I want to spin just one of the parts, I select the part with the RMB, holding it down and spin it.  The RMB doesn't seem to work in my sessions of Onshape.  Can anyone let me know if it's possible or what I'm doing wrong?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,932 image
    No, it is not possible. Select the part and use the manipulator to rotate it. You can also suggest this as an iomprovement request in the category on the right ==>
  • martin_kopplowmartin_kopplow Member Posts: 1,078 PRO
    I once tried a beta version of some other CAD where a part that had the manipulator on it could be moved 6DOF using the space mouse. That required some getting used to, but was good for trying things out or explaining the mounting process. It was not precise enough for design, though it could possibly be useful in combination with mates in snap mode.
