Putting Text Information in Model
colin_starker933
Member Posts: 34 EDU
********** I'm not posting to debate so please do not respond trying to convince me of anything, just move on (even if you're a dev). **********
I need some way of putting text information in the CAD model. Normally, I would make heavy use of 3D leader text and general notes, but OnShape lacks this.
I looked for something similar to the Engineer’s Notebook in
Inventor. I found nothing that’s native or in extension.
Next, I looked to Properties for a field that is instance-unique (only visible
in the Properties of a specific instance in an assembly and not propagated to
the part in general). This also does not exist natively or in extensions.
I found Comments, but I don’t really want to use these for this purpose. Comments are for, as the name suggests, commenting and making suggestions. It would be bad practice to put important information and hyperlinks in these.
Until we move our simulation over to OnShape, we will have a
ton of unlinked simulations. In SolidWorks, we had notes and leaders all over
the place containing links and explanations. This is pretty much non-negotiable
for us. I hate to be the guy that says his request is a “basic feature”, but
this truly is a basic feature that’s missing. Engineers need to make notes.
Does anyone know of any hidden features of extensions that I haven’t found that
allow me to add notes to models?
NeilCooke
Moderator, Onshape Employees Posts: 5,891
Move on.Senior Director, Technical Services, EMEA5
Proper orbiting was eventually added, despite the devs insisting that it was not an established CAD standard. Let's hope the pattern holds and we get notes and leaders.
CAD Engineering Manager
This is very close to doing the job, but comments appear to be applied at the document level, not the assembly level. For this to work, the comments would need to be pulled by any document that pulls the assembly.
This does serve the same purpose, but there is no way the people I work with will accept this.
Agreed…many things missing in Onshape…need notes in all environments.
• For now, Ste_Wilson's suggestion will have to do but it's invisible to everyone unless they specifically click on the comments icon at LH toolbar.
Strangely, the comment icon only becomes visible beside the feature its attached to when the LH button is clicked.
•Onshape should at least have this show at all times to allow other designers or purchasing group the ability to see at a glance.
(ASME stipulates that notes get missed & should be avoided but sometimes they're necessary…making them as invisible & out of mind as possible isn't the path to success)
