New Feature: 3D Printed Hole
EvanReeseEvanReese Member, Mentor Posts: 2,686 PRO
edited January 2022 in General
I finally made time over the holidays to knock out a feature I'd been wanting to write for a while. It automates the process of converting round holes to a droplet shape so they 3D print cleanly without support material. I made a video tour here to show off all the bells and whistles. Go get the feature here. Let me know what you think!
It does this to holes:
  • MichaelPascoeMichaelPascoe Member Posts: 2,681 PRO
    Yess!  Thanks @Evan_Reese
    Nice work @Evan_Reese!  Can you offer any guidance on how much 'tear-dropping' is required to maintain clearance for a round pin?  I realize that there are a gazillion variables involved from printer and material characteristics to hole size and orientation.
    But if you were looking for minimal modification on a Ø1/4" hole, perpendicular to the build-direction what would you recommend?
  • EvanReeseEvanReese Member, Mentor Posts: 2,686 PRO
    I'll probably just leave the Overhang Angle at 45° pretty much always, and then not think too much about how tilted the holes are or aren't since the feature automatically adjusts the amount of tear-dropping for you based on the hole angle. You still need to design the hole with some clearance to the shaft before using this feature. I'd probably start with 0.2mm for a rigid connection or something like 0.5mm for something meant to slide, but if I wanted to dial it in I'd do a test print with lots of holes slight variations in clearance to find the best one. Did that answer the question you asked?
    Answered.  Thanks @Evan_Reese.
  • mahirmahir Member, Developers Posts: 1,319 ✭✭✭✭✭
    Nice. I've never even seen that type of hole for 3D printing. But I could have definitely made use of it and will do so in the future.
    I like it. I'm not sure if it's the first place I learned about it, but Angus from Maker's Muse explains it well. It's not just about overhang angles, it's also about how it's hard to approximate a round hole by slicing it into layers. https://youtu.be/j6508J94VsA
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 466 PRO
    @Evan_Reese
    Thanks for the amazing Feature-Script!
    I just used it in a print  :)
    @Evan_Reese
    Nice! glad it was useful
  • marshall_polandmarshall_poland Member Posts: 10 PRO
    Fantastic, I will use this a lot @Evan_Reese ! I just posted an improvement suggestion exactly for this, but will remove it since this covers it about perfectly.
    wohoo! thanks for letting me know.
  • STEGSTEG Member, User Group Leader Posts: 139 PRO
    edited March 2024
    Great work! 👍
    Truncate is what I was doing manually.
    Glad to hear it
  • jelte_steur_infojelte_steur_info Member Posts: 603 PRO
    edited April 2024
    Hi @Evan_Reese
    I always use the 'truncate' setting of your 3D printed holes feature but have had it fail on me a couple of times.
    I've copied and changed the code to make it more robust.
    Moreover in one of my cases the evDistance in getPrinterZDirection function failed and it caused the whole feature to fail. I've haven't solved the rootcause  but made it so the feature still resolves. (couldn't quite figure out why the evDistance failed)
    I'd love for the community and you to benefit from my improvements rather than just forking another version off that won't benefit from future improvements.
    Can i share it with you to integrate it when you find the time?
    kind regards
    Jelte
    Hi @Evan_Reese
    kind regards
    Jelte
    Thanks for looking into it! I'd be happy to incorporate improvements. Go ahead and share it with me if you don't mind. The more you can do to explain what you changed an why the better too.
    Thanks again to @jelte_steur814 for the code edits to mitigate some of the failure cases! I've got his code implemented and running in the newest version of the feature.
    awesome @Evan_Reese
  • lennert_hlennert_h Member Posts: 2
    Hey @Evan_Reese the video doesn't seem to be available anymore. Would it be possible to rerelease it?
    Thanks for checking. I'll need to make an updated one as the youtube channel for my old company cleared out my videos. It's in the backlog! Feel free to ask questions here in the meantime.
