Slow preparation speed
I've been working on a model recently and it's slowly become harder and harder to actually make new extrudes and fillets and all due to the "preparation time" I'm unsure what the problem is, I'm fairly new to onshape but, this doesn't seem normal. I have a high end gaming PC with a high end CPU too. I checked the performance tab and nothing seems to make sense for causing the performance issue. I've tried testing my browser compatibility along with other recommendations but nothing seems to help reduce the nearly 10 second preparation time. it really causes it to be almost impossible to work on the model. anyone have any recommendations?
I have noticed this in the changelog from today's release:
"Fixed an underlying issue that can cause slowness when editing features and sketches"
I'm hoping that will help, check to see if it still happens after your document is updated to the latest version...
TVP, Onshape R&D
TVP, Onshape R&D
However if I still see long "preparation" times after it has been updated to latest version I will submit a ticket.
