Sheet nesting for parts
doug_hillsdoug_hills Member Posts: 29
Hi everyone,
I'd like to learn how to export the parts in a way that they can be imported to a nesting tool for sheet cutting.  ie panels for a cabinet, etc
https://deepnest.io/ was suggested to me in a FB forum.
If I export a "Drawing" of a part, the whole page gets exported and imported to the nesting software, and appears as an 8 1/2 x 11 "part" rather than the actual part.
I'd have to be able to export the " views" so you have the "face on" sizing of the part, rather than the "front" view of a slopped part.
Thanks for you guidance,
Doug
  • wayne_sauderwayne_sauder Member, csevp Posts: 616 PRO
    @doug_hills
     RMB on the face of the part and select the DXF or DWG option.
  • dave_lapthornedave_lapthorne Member, Onshape Employees, csevp Posts: 36
    If you have multiple sheet metal models and flat patterns in your model you can choose to export all the flats in one step.
    1. Open the Sheet metal table and flat view from the right side toolbar
    2. RMB on the flat and select Export DXF/DWG
    3 Edit the export options to suit
    4. Under the Scope dropdown you can choose from the 3 export scope options.
    Onshape QA Engineer
  • doug_hillsdoug_hills Member Posts: 29
    thank you, this doesn't fit my immediate requirement, as I doing wood. But who knows what I'll be doing next month.
    Wayne, Thank you. As usual, so obvious, when you know where to look.... I also found that if you select the part first, the export isn't there. you have to RMB directly on the face, not the selected part. Thanks again.
