How to copy the face of a body?
jason_bennett190
Member, Developers Posts: 17 ✭
In the mean time, what do you intend to do with copy? In many cases you can directly use the original face, without creating a new surface.
I will look forward to opExtractFace. For the time being, manually creating a sketch of the surface adds less than a minute to my workflow, so not a big deal. If I get impatient, I have a good idea of how to write a tool using existing operations.
Thanks
You can try using the face itself in feature creating the new body (New option in extrude etc.) and moving the newly created body, if that makes sense.
best regards, franco
a 0 offset offset faces works. but this custom featurescript may look cleaner and in your feature tree.
I'll be using it with 'delete original faces' set most of the time in my surfacing work.
https://cad.onshape.com/documents/779f5788eaaef8fbd16e4633/w/df3a0ee440fca5e27758ad14/e/0b50ca056c3037b1df28d85b
