Third angle default
david_hollisdavid_hollis Member Posts: 2 ✭✭
Is it possible to add the setting of the projection type in the work space tab where we change to metric. Maybe even a choice that says Australian standards
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,862
    Projection type is set in drawings only - 1st angle for ISO templates, 3rd angle for ANSI
  • philip_tallents890philip_tallents890 Member Posts: 2 EDU
    I need A3 size with 3rd Angle. ANSI doesn't do A3, and ISO doesn't do 3rd Angle
    You can set the projection angle once the drawing is created (right-click to see sheet properties) or you can create your own template.
  • robert_paynter531robert_paynter531 Member Posts: 4 EDU
    But the Symbol in the title block doesn't change!
    True - you still have to change the template.
