Perspective View
digitalcarbondigitalcarbon Member Posts: 102 PRO
I work in perspective view in my architectural cad system and would like to have it always turned on as my default for Onshape...is that doable?
Its just more like real life.
    @digtalcarbon It is not possible right now, but I have pulled a ticket for you.
  • ricky_barnabyricky_barnaby Member Posts: 10 ✭✭
    What is the keyboard shortcut TOGGLE, for perspective view ON/OFF? please anybody?
  • Theo_RTheo_R Member Posts: 82 PRO
    @Jake_Rosenfeld
    Here's a related IR - would love to see perspective field of view control.
    Thank you!
  • jtargownikjtargownik Member Posts: 11 EDU
    any update on this?
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,049 PRO
    any update on this?
    Its under the view cube, on its drop down. "turn perspective on"
    Great BUT... What is the keyboard shortcut TOGGLE for perspective view ON/OFF
  • david_brophydavid_brophy Member Posts: 53 ✭✭
    Yes I'd love to toggle perspective view on / off with a button on my SpaceMouse Pro. If would be great if this could have a keyboard shortcut.
  • STEGSTEG Member, User Group Leader Posts: 139 PRO
    I don't know for Onshape (never tested) but I remember that when using Autodesk Inventor, perspective view was pulling so much graphic power from my GPU (which was recent and powerful) that I stopped using it.
  • null_null3941null_null3941 Member Posts: 17
    HI Jake was this ever developed to change the perspective value?
  • martin_kopplowmartin_kopplow Member Posts: 1,195 PRO
    I usually don't use perspective view in OS because it has an overly wide FOV and creates too heavy distortions, not looking natural at all. Maybe it's just me, but I also have the impression that the distortions get the greater the larger the screen is. On a 4K screen it is already pretty ugly and on the even larger one in the meeting room, it is pretty much unusable. If there is a perspective view in the modeling tabs, there should also be a setting for FOV and another setting to hide all faces that get behind the camera while navigating though the model. Especially for architecture, that would open up possibilities for a walkthrough mode, which, in combination with the follow me mode, could be quite useful.
  • nadim_khemirnadim_khemir Member Posts: 2 ✭✭
    Hi, any update on field of view control? right now I find it too wide and the possibility to control it would be great.
  • MannyFMannyF Member Posts: 19 ✭✭
    Any update on this? I would like a default setting for this or, at least, a shortcut so I can toggle this quickly. It seems to revert to perpendicular view of its own accord which is inconvenient for those of us who prefer perspective view. Thanks!!
  • mark_cocquiomark_cocquio Member Posts: 2
    It's 2026 now… would love this as a permanent setting. Please :)
  • CADNurdCADNurd Member Posts: 44
    You can now assign a keyboard shortcut to toggle perspective . . .
    Also, you can now adjust the 'depth' of the perspective view via the 'field of view' setting in Graphics Preferences . . .
    CADNurd's Linktree - find me everywhere else - https://linktr.ee/Liam.G
