@connor_mcbride, give Dark Reader a try. Works great!
which I find harder on the eyes since you go from calm and dark to bright white when opening a drawing
See Discussion
the icons are still a bit fuzzy, but I like the color mode and dark drawing!
It made be give them my email for a free trial... but I didn't see anything about cost. (I went through install pretty quick)
Is it free forever? or what?
I don't know what the deal is, I saw that it was $3.99 for a lifetime. But the other day my free trial expired and I paid $2.99. I understood this to be a one-time fee.
Buy the way I told Onshape they should buy this from the developer and bake it in. With a few refinements.
Onshape dev team isn't working in their closed door office, hoping the new features they develop will be appreciated by the users, they work with the users and listen to them.
Unfortunately, sometimes the result isn't perfect. But most of the time, it is great!
The improvement I'm requesting here is something I already requested months ago. But keep in mind that they have to prioritize (with many factors into consideration) and paying or not, we can't always get what we are considering a top priority (like for this request for example).
Is Onshape perfect? No. Do I want to use another CAD software? HELL NO!
One of my colleagues, a better drafter than I and the engineer who got me hooked on OnShape, looked at this hole feature and said "OnShape needs more mechanical engineers and fewer software engineers." This isn't a sentiment I agree with, but the fact that she would have that opinion at all is worth keeping in mind.
Hi Onshape Team,
Congratulations! Another set of awesome updates. I particularly like the SKETCH DIMENSION EXPRESSION DISPLAY.
While testing it out, I was curious about using it in an inactive sketch.
Sample Photo:
I wonder if you would also consider activating this feature in inactive sketches, alongside other variable-driven tools like Extrude, Revolve, and so on.
Thanks!
CAD Engineering Manager
The "Show Expression" checkbox does not stick after closing the Sketch, this must bu a bug otherwise is useless. Also, the Expressions need to be visible without needing to go into Edit Sketch mode.
we are UK based so this is mostly relevant to metric threads
1) the selection would be super helpful to default to course pitch when a size is selected as these are the standard for metric threads and save us accidently putting fine pitches in there.
2) the fastener fit needs to be disabled as there isn't one for a tapped hole and we keep forgetting this and not understanding why the feature isn't working.
3) the thread class needs to not be here but if it is, it needs to not change the nominal size of the hole put into the model, the minor size drilled is dependant on the tooling used to machine the tapped hole so should just be a standard tap drill size, why has this been done at all? we are having to change all of this as we go straight to CAM from the model and its causing us real pain, normally we only expect to see the tolerance class of anything within the drawing options, not at model level.
to get it back copy this featurescript std | hole.fs (onshape.com)
then delete "unconfigurable" from lines 351 and 354
If it's a custom feature then it will have a blue update icon to notify you
Otherwise contact support
