How to make an assembly into a dumb solid outline 3D file from a STEP file in OnShape?
bob_swidarskibob_swidarski Member Posts: 7
What are the easiest ways to make (1) a part and (2) an assembly (or subassembly) into a dumb solid?   The idea being a packaging design team doesn't need to access to the valves inside an engine design to build a crate for it.
I have an existing STEP file from another source.   That STEP file has a number of parts. I am able to successfully group them into three sub assemblies.  I then want to export them individually into a dumb solid files.
I had some success exporting them to a file type that would do this.   However, it was incorrect in that the parts instead of exporting as a solid block as oriented in the subassembly file it basically stacked all the parts centered on the origin.
I'm sure it's a one or a mix of choosing the right document types, setting a property somewhere, separating the three subs into different tabs, creating part relationships in the subs or the right file type an export settings.
Can anyone walk through how to do this (or point to the right video or guide)?
  • In OnShape.
  • Using the existing STEP file.
  • Assume it's provided by 3rd party
  • And won't get editing in the source it can from.
  • Only changes will occurs in OnShape.
Much appreciated!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    edited March 2024 Answer ✓
    Try this https://cad.onshape.com/documents/3f84343841cb6d7fead072c8 - removing internal detail is optional.
  • bob_swidarskibob_swidarski Member Posts: 7
    How does one find the Simplify feature?  Not seeing it.  Thanks.
    Click on the link above then click the "+ add custom feature" button at the top to add to your toolbar
    @NeilCooke Video is great.  Seems to do exactly what I am looking for.    HOWEVER   the Simplify feature... is that something extra?  I don't have access or can't find it.Said otherwise, how does one gain access to that feature?
    Beautiful.  Thank you.
    After simplify, I'm getting two parts as a result instead of one.   "Simplified Part"  and then another Part.   I tried with a couple starter files.
    I'm following fine thru 4min, then at 4:11 I'm getting two parts instead of one simplified part.
    File structure is .x_t.   Part A and Part B exist centered on the origin in a part studio tab.  On an assembly tab Part A and Part B have correct spacial orientation relative to each other.   I'm making the file per your video from that assembly tab and using origin as a reference.   I'm ending up with Simplified Part and Part B, Parts (2) at the bottom instead of one Simplified Part.
