Mirror AND Merge?
christopher_owenschristopher_owens Member Posts: 235 ✭✭
Hello! Now that I have got to the point where I want to "Mirror" my part about a center plane, I would want the finished "mirror" to be merged into Part 1. There is no selection for this to happen during the "Mirror". I will have to create a Boolean-Merge to make both halves one part!
PS Again, would be nice to have "Upload" image while asking a Question!
    Here is the Uploaded image...
    This creates Part 6...
    Which then is Boolean-Merge into Part 1.
    What is the problem with boolean merge?
    If mirror feature had it's own merge, it would work only when halfs are touching each other; that is not always the case.
    Though, I wouldn't mind if there was a merge box similar to extrude.
    Nothing wrong with it... just an extra step!
    Although I did make good use of Extrude-Remove; Move Face-Rotate; Draft; Fillet to create the corner "pocket". Then Extrude-New-Up To Surface (using the same sketch from the first feature and the now rotated bottom surface of the pocket); Boolean-Remove Part 1 from Part 2-Keep Tools (to get the draft and fillet on Part 2 and have all be driven);Pattern Part (Part 2)-Two Directions; and the Boolean-Remove (Part 3 & Part 5 from Part 1) to recreate the corner pocket and have them all driven!! I am learning! (Part 4 in the Pattern is hidden)
    Lets just say, we are very aware that this would be a very cool capability :)
    Philip Thomas - Onshape
    Mr_SnrubMr_Snrub Member Posts: 3 PRO
    any luck on mirrored features being optionally merged these days?
    Thanks!
    _anton_anton Member, Onshape Employees Posts: 292
    nick_papageorge073nick_papageorge073 Member, csevp Posts: 679 PRO
    Thanks!
    It's done that for many years. You must be in the "new" tab within the mirror tool. Try any of the other tabs.
