Get a Vector from an Edge
Alex_PittAlex_Pitt Member Posts: 76 PRO
Is there a way to convert an edge (query) to a vector?
I've asked Chat GPT but it just seems to make stuff up...
"Hi, Chat GPT here,
In Onshape FeatureScript, you can convert an edge to a vector using the opEdgeToVector function. This function takes an edge as input and returns a vector representing the direction of the edge.
Here's a simple example demonstrating how to use opEdgeToVector:
javascriptCopy codeimport(path : "onshape/std/geometry.fs", version : "252.0");
// Define a simple edge
const edge = edge(context, {
    start: vector(0, 0, 0),
    end: vector(1, 1, 1)
// Convert the edge to a vector
const edgeVector = opEdgeToVector(edge);
// Print the result
println("Edge vector: ", edgeVector);
This script creates a simple edge from the point (0, 0, 0) to the point (1, 1, 1), then converts this edge to a vector using opEdgeToVector, and finally prints the resulting vector..."
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,958 image
    edited April 2024 Answer ✓
    You got it.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 371 image
    You’ll need to look at the help/tutorials a bit to get the fundamentals. ChatGPT clearly does not understand the difference between queries and evaluation, amongst other hallucinations it’s having.
    Evaluate is what you need to do to a query that refers to an entity like an edge.
    Check out evEdgeTangentLine in the docs….
  • Alex_PittAlex_Pitt Member Posts: 76 PRO
    @GregBrown thanks. Haha yes! ChatGTP can be very "creative"!
    I'm not up to speed enough for the help to mean much... evEdgeTangentLine(context, map) returns line.  If this will somehow return a vector from an edge query I will investigate further.
    Re tutorials, I did the Fundamentals course a few years ago which is very good but I'll need to revisit. I'll keep plugging away. I'm sure it will twig in time.
    This could be helpful...
    var myLine is Line = evEdgeTangentLine(context, {
        "edge" : definition.edge1,
        "parameter" : 0.5
    var myPoint is Vector = myLine.origin + myLine.direction * 2.5 * inch;
    debug(context, myLine);
    debug(context, myPoint);
    When I tweak the above to this...
        "edge" : edge1,
        "parameter" : 0
         var myPoint is Vector = myLine.origin + myLine.direction *0*mm;
    The debug looks like this.
    debug: Line direction (-0, -0, -1)
    origin (0.1 meter, 0meter, 0.3 meter) //that's the top point of my selected edge
    debug: Vector (0.1meter, 0 meter, 0.3 meter) //same point as above
    debug: Vector (0.1 meter, 0 meter, 0.3 meter)
      Result: Regeneration complete
    I can now get the length of my edge. (0.3m) by multiplying the respective components of the Line direction unit vector (-0, -0, -1) and the myLine vector (0.1m,0m,0.3m).
    Seems a very convoluted way to do it though.
    Is it the length you are looking for? evLength?
    @NeilCooke Thanks, evLength is great as I do need the length. I also need the unit vector (line direction) of my edge. I plan to multiply the two, to get a vector to feed into opTransform. (All part of my cunning plan to move a part along an edge).
    I'm unsure how to get the unit vector so I'll have a look through the help. Maybe one of the evaluate functions...
    evEdgeTangentLine returns a Line object where the “direction” is a unit vector.
    @NeilCooke thanks. Yes I saw that.
    A "Line" is a special kind of "map" is that right? Direction + Point. Infinite length.
    Unsure how to isolate the "direction" component of that "Line".
    Looking to the help...
    "...Map elements are accessed or changed using the map key. If the map key is a string that is a valid identifier, dot syntax may be used.
    var val = map2.a;       // v is 1
    val = map2["a"];        // v is 1
    map2.a = 0;             // map2 is now { "a" : 0 }
    map2.b = 1;             // map2 is now { "a" : 0, "b" : 1 }
    So maybe..
    myLine.direction
    You got it.
    edited April 2024
    It works! :smile:
    Thanks Neil & Greg.
          var myEdgeLength = evLength(context, { "entities" : myEdge });
           var myLine is Line = evEdgeTangentLine(context, {"edge" : myEdge, "parameter" : 0  });
           var myVector is Vector = myLine.direction*myEdgeLength;
           opTransform(context, id + 0 + "transform1", {"bodies" : myBody, "transform" : transform(myVector)  });
