Get a Vector from an Edge
Is there a way to convert an edge (query) to a vector?
I've asked Chat GPT but it just seems to make stuff up...
"Hi, Chat GPT here,
In Onshape FeatureScript, you can convert an edge to a vector using the
"Hi, Chat GPT here,
opEdgeToVector
function. This function takes an edge as input and returns a vector representing the direction of the edge.Here's a simple example demonstrating how to use opEdgeToVector
javascriptCopy codeimport(path : "onshape/std/geometry.fs", version : "252.0");
// Define a simple edge
const edge = edge(context, {
start: vector(0, 0, 0),
end: vector(1, 1, 1)
// Convert the edge to a vector
const edgeVector = opEdgeToVector(edge);
// Print the result
println("Edge vector: ", edgeVector);
This script creates a simple edge from the point (0, 0, 0) to the point (1, 1, 1), then converts this edge to a vector using opEdgeToVector
, and finally prints the resulting vector..."
NeilCooke Moderator, Onshape Employees Posts: 5,884
You got it.Senior Director, Technical Services, EMEA0
I'm not up to speed enough for the help to mean much... evEdgeTangentLine(context, map) returns line. If this will somehow return a vector from an edge query I will investigate further.
Re tutorials, I did the Fundamentals course a few years ago which is very good but I'll need to revisit. I'll keep plugging away. I'm sure it will twig in time.
var myLine is Line = evEdgeTangentLine(context, {
The debug looks like this.
debug: Line direction (-0, -0, -1)
I can now get the length of my edge. (0.3m) by multiplying the respective components of the Line direction unit vector (-0, -0, -1) and the myLine vector (0.1m,0m,0.3m).
Seems a very convoluted way to do it though.
I'm unsure how to get the unit vector so I'll have a look through the help. Maybe one of the evaluate functions...
A "Line" is a special kind of "map" is that right? Direction + Point. Infinite length.
Unsure how to isolate the "direction" component of that "Line".
Looking to the help...
"...Map elements are accessed or changed using the map key. If the map key is a string that is a valid identifier, dot syntax may be used.
myLine.direction ?
Thanks Neil & Greg.
