Can Onshape texture a sketch region?
fred_wildfred_wild Member Posts: 29
I see how Onshape can color a sketch region using the Offset Surface feature with Add Appearance.  In a similar purpose to distinguish a sketch region, can Onshape "texture" a region to have it show as plywood, wood, or just crisscross, dots, or lines?  I researched "Texture" in Onshape help without success. Thank you.
