How to search for a Document Name, when only a few middle characters are known.
How can I use a "wild card" for Document File Name search that contains a sequence of characters in the middle of the Document Name?
For example: *Connector*
eldon_brown Member Posts: 50 ✭✭
glen_dewsbury
***** Try "*mets*" as your search, I do not think it will work! *****
CORRECTION: I must not have be waiting long enough, It now WORKS for me also as "*flag*" !
(I must have too many files or a slow network connection)
Thanks, this answers the Question, Thanks ALL
I can now go back to my "CamelCase" and "Snake_Case" file names as desired.
Thanks.0 -
S1mon Member Posts: 3,326 PRO
What I have found is that searching for "foo" will find "blah-foo-baz" and "blah Foo baz" but not "bing_foo_bar" nor "BingFooBar". Searching for "*foo*" will find all of them, but takes longer.Underscores or camel case don't work as well for Onshape search, especially for people that forget to use the asterisks.1
Thanks.
