Is there any way to fetch all parameters can be used to create a feature?
liang_dai
Member Posts: 5 ✭
Is there any way to fetch all parameters which can be used to create a feature such as sketch, extrude, etc. Using Get the Feature List end point won't list all parameters and I can find any document to learn those params which makes me confused when I using feature-creating rest api to create my own feature
NeilCooke
Moderator, Onshape Employees Posts: 5,927
OK - does this page not give you everything you need? https://onshape-public.github.io/docs/api-adv/featureaccess/Senior Director, Technical Services, EMEA0
