Rotating a polygon in sketch
michael_drollmichael_droll Member Posts: 4
I am trying to rotate a inscribed polygon in a sketch about the center point, but when i rotate with the transform tool only the construction circle moves and not the lines?
  • glen_dewsburyglen_dewsbury Member Posts: 1,361 PRO
    Can you make your document public and share a link? Will help to see your issue first hand.
  • mfalkensteinermfalkensteiner Member, Onshape Employees, csevp Posts: 87 image
    Be sure to select the lines of the sketch and not the construction circle when using the Transform feature.
    Principal Technical Services Engineer, EMEAI
  • rick_randallrick_randall Member Posts: 426 ✭✭✭
    edited April 2024
    When you created the polygon, did you infer any horz. or vert. constraints to the polygons handle ? If you did, you need to delete those constraints before you can revolve the objects (lines).  The circle can be defined (black), but the lines must be under-defined (blue). Is this what you're after? It worked for me.
      P.S. - This method works for rotating text as well (look for horz. or vert. constraints and delete before rotating).
    Good luck
  • michael_drollmichael_droll Member Posts: 4
    https://cad.onshape.com/documents/9c78168b1ea5ee28d45be859/w/efea0ed67c8e96785fb87855/e/2f59b94817efe34a74bcd3b3mfalkensteiner said:
    I tried that but then the point of rotation is not the centerpoint
  • wayne_sauderwayne_sauder Member, csevp Posts: 662 PRO
    @michael_droll
     Why use the transform at all?
    You can delete the constraint preventing rotation (likely the point at the tip of the arrow for 10x has a midpoint and a horizontal constraint) and rotate around the center point. Maybe I missed something.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,062 image
     Try dragging the transform tool to the centre of the circle........
    What Neil said - grab the tiny circle at the center of the triad , then drag and drop to where ever you want the rotation to be centered.
