Rotating a polygon in sketch
![michael_droll](https://cad.onshape.com/images/placeholder-user.png)
I am trying to rotate a inscribed polygon in a sketch about the center point, but when i rotate with the transform tool only the construction circle moves and not the lines?
Why use the transform at all?
You can delete the constraint preventing rotation (likely the point at the tip of the arrow for 10x has a midpoint and a horizontal constraint) and rotate around the center point. Maybe I missed something.
