How to use the tangent mate correctly?
kees_bijker
Member Posts: 171 ✭✭
In this document called tangent mate trial, I tried to get the cam follower face to follow the face of the cam. The trouble as I can see it is that my cam face is a compound of several faces but the mate only recognises the first one you select.
What can I do to make this system to work so the cam follower is going to follow the whole face of the cam as the camshaft turns around?
NeilCooke
Moderator, Onshape Employees Posts: 5,979
Well, you could try making your arcs tangent in Sketch 2.Senior Director, Technical Services, EMEA1
