How to create perforations along a curved solid?
ignas_savickas420
Member Posts: 2 ✭
What is the best way of creating perforations along a curved solid? The pattern along curve tool does not appear to work. Perhaps I am making some mistake somewhere? Any help would be much appreciated.
https://cad.onshape.com/documents/5e44989120f8c9dbf35ccf13/w/a90e308604f6154bbd8f98ea/e/cd662d85f63bc642da0cb2d9
TL.DR
I would like to know what is the best way to repeat hole every 14mm along the solid.
https://i.imgur.com/0EaNHFp.png
TL.DR
NeilCooke
Moderator, Onshape Employees Posts: 5,932
Create it as a sheet metal model, then sketch/pattern the holes on the flat
Senior Director, Technical Services, EMEA8
After make such approach regeneration time is 296s
DO you have some different approach for those type of models?
