Wood grain texture Custom Feature
TimRice
Member, Moderator, Onshape Employees Posts: 315
Often when modeling furniture and other objects created from wood I want to communicate the orientation of the wood grain on a part. This eliminates confusion when creating the parts in the workshop. To solve this I created a Wood grain texture custom feature! This low resolution feature is intended to demonstrate the overall grain direction without degrading performance with too much detail.
Add to your toolbar here:
https://cad.onshape.com/documents/f5cd9f4b2ec8e9eea7266f1e/v/59e3340e9e7ef9d664172a84/e/595af5842cd8801d37dc3da5
Onshape, Inc.
Onshape, Inc.
15
Would have been easier if y'all would add colored faces/textures
Check it out!
https://cad.onshape.com/documents/f5cd9f4b2ec8e9eea7266f1e/v/37c68c0d9ae053e9f22e23b6/e/595af5842cd8801d37dc3da5
Onshape, Inc.
This is probably the most well made custom feature I have used.
I only ran into a few issues.
The grain "sketch" was not large enough for large parts and would only put grain on a portion of the part. - (Consider having the sketch stretch to fit the selected part)
The grain was not dense enough to see easily on small parts. - (Consider adding the option to have more or less dense grain)
Again, very nice feature!
@david_mcmahon Thanks I will add some info on setting the origin in the FS doc.
Onshape, Inc.
I was attempting to use the feature to show that there will be grain on these portions of the cabinet when viewed from the side for architectural drawings. The grain was not large enough to fit on all of the portions. I tried using the linear pattern and switching the grain up, but it would not come out quite right. I think being able to select how close together the grain is and to be able to pick any size of part, will be useful.
Great, thank you for the example! In this case I would imagine you would need to apply an individual feature for each major part. Then you can use a Feature linear pattern with Apply per instance workflow that I mentioned above. You can control the interval between pattern instances to get a repeating end grain across the given part. The trick here is to offset the origin so only a portion of the grain pattern fits on the part:
I also can see the need to control the overall scale of the pattern. I will work towards adding this in the future!
Onshape, Inc.
Added a scale input and instructional PDF in V1.2.3! Just update the reference in your toolbar to get the latest features!
Onshape, Inc.
Thank you!
Onshape, Inc.
First you can add it to your toolbar:
and then apply it to entire parts:
Onshape, Inc.
If anyone needs a 3D printable Desktop monitor stand/riser quick and dirty model, but should work fine.
https://cad.onshape.com/documents/8f1c02b49f744604f6da68c5/w/e1a6bb0fb9cf01d0a2238898/e/a9cca57a6d711aaac1ae0b3e
edit: figured out how to offset the origin by just clicking on the mate connector box in the wood grain pop-up.
I just google an image of wood, then add it to the faces of the part.
here is the raw image you can download for plywood:
but if I wanted more clearity I would go download a side view image of plywood then make it long enough in MSPAINT...
That's how I did the brushes on that project
Obviously I couldn't find matching colors for bristles when I did it, but the representation is there. In this case it looked better this way rather than having a smooth face. But for the wood handle, I didn't bother with wood texture, since it looks good enough to get the idea across that it's a hand brush
On that note:
the plywood got nixed before release, so we went with a pallet,
Since a pallet is obvious, I didn't find the need to texture it with wood, just a wood tone.
I only did the bristles and plywood, because it made it easier for the customer to identify everything from a PDF assembly.
and also because we do a lot with sheet metal, and I have seen them burn a piece of 1/2" sheetmetal on the laser to make a part, because they didn't check the material was plywood
but you're going to take a performance hit by using it
hi, i am quite new to onshape. i am wondering how to actually get the wood grain custom feature
@him_chong
See the quoted comment ^^^^
