Reorder Cut List
JPM
Member, csevp Posts: 23 ✭✭
Maybe I'm missing the obvious, but is there a way to reorder a cut list without having to reselect the items in the correct order? I just found an item that wasn't included and I'd like to add it. We typically list our tube by cut length, longest to shortest.
Thanks!
Thanks!
NeilCooke
Moderator, Onshape Employees Posts: 5,927
Sorry, but there is no way to do this right now.Senior Director, Technical Services, EMEA0
There is a work around @caq1, but it would involve developing your own modified version of the Cutlist feature so that it re-orderes the cutlist entries. You could do it yourself, or have someone else do it for you.
Let me know if your interested in having someone do it for you, I can set up a discovery call for you with CADSharp.
This is a good idea!
Please file the feature request via the "Contact Support" button:
Or you can post it here, in the feature request category, so other people can vote on it as well: https://forum.onshape.com/categories/improvement-voting
