Cross Sections
Unless I am missing something, cross sections work well but only horizontal and vertical are limiting. We need to be able to create other cross sections, such as one that is perpendicular to a selected edge or at a specific angle. Other packages I am familiar with, you can create a line for the cross section, then use it. The line turns into the section line and a view is generated from that.
2
https://forum.onshape.com/discussion/134/how-can-we-make-section-views-awesome-in-onshape/p1
@shashank_aarya
This is a different discussion topic. Section views in drawings (being discussed here) do not currently relate in any way to section views in models.
I'm guessing Lou's comment also falls on the wrong side of this divide.
While it's very easy to miss the "Drawings" category in small print in the header of the OP, I'd have thought that the discussion of "vertical and horizontal only" in the OP was a bit of a giveaway, as this limitation only applies to drawings.
Another serious whatsit in the section view woodpile is the current inability to move the label away from the view.
This means that no dimensions can be arranged underneath the view, as their extension lines would have to run across the view label.
There is a more subtle whatsit: when you try to drag a Section View Label away from the view, using the central handle (which is the only viable way to drag, say, a dimension) the label stays stubbornly stuck.
Whereas when you drag from elsewhere in the box, a preview shows the label moving.
However when you release the mouse button, it snaps back to where it started.
This sort of investigation is made tedious and frustrating by the massive latency, at least on this side of the planet, opposite where the servers presumably reside.
BTW, producing this drawing was like a trip down memory lane, to the days before the PC.
It was like drawing in ink on tracing paper with a Rotring lettering template, except slower and more frustrating.
And the result is only good enough for use by me in my own workshop:
I would never permit a client to clap eyes on something so amateurish and constrained
I need to move all the left hand dimensions further from the sectioned part. I assumed I could select them all (which worked fine) and than drag one and the others would maintain their relativity (which didn't: only the one I dragged moved)
Given the latency, it would take me about ten minutes to get them all lined up at a suitable distance from the item.
Which is similar to what it took to carefully scrape the ink away with a scalpel and painstakingly re-letter each dimension, in the bad old days...
... So my feedback is severely limited by only being able to use Onshape for drawing items I'm making with my own hands.
The items have to be extremely simple, like the component shown here, and even then, I have to have plenty of spare time to wrestle with the latency and lack of functionality. And further time to write up for the forum. So I guess this is by way of explanation for why I won't be able to contribute much if anything to the drawing module development, at least until much later in the process.
