Importing an Image.
I've looked at other posts, I couldn't find anything helpful for me.
Im trying to import a photo and can't, I made a sketch, pressed import image, but the actual file import isn't there.
Can I get some help?
Thanks.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    Did you import the image first, either separately or by clicking the import button at the bottom of the insert an image dialog?
  • benson_booth782benson_booth782 Member Posts: 2
    i have also had this problem and the import button is not there or is covered at the bottom
