Having problems generating End Caps on Beams
paul_wattonpaul_watton Member Posts: 4 PRO
For some reason, the End Cap feature won't work for me, even though I'm following the correct procedure for generating them.
The error message I'm getting is "End Cap did not generate properly. Invalid selection." That's despite having carefully selected the end face of a beam / RHS profile.
Has anyone had the same problem and therefore have any suggestions as to how to correct it please?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,037 PRO
    I haven't had an issue before.
    can you share your document, or make a video showing what's happening?
  • paul_wattonpaul_watton Member Posts: 4 PRO
    I've figured it out.
    If, as I have been doing) you generate RHS sections via the "Beam" function (as opposed to selecting from the menu of beam profiles available via the "Frame" tool, then the "End Cap" tool won't work.
    So, changing the way that I generate the structural steel profile, corrects the problem.
