How to break color derived selections
jrose2001
Member Posts: 5 PRO
I am doing a simple copy part using transform. I need to be able to change the color of individual faces of the copied part but am running into something new. It now says the color is a “derived selection”. I can’t find any way to stop this or break the link. In the past this was not a problem so something has changed recently. Any help is much appreciated
rafael_telgmann
Member Posts: 138 ✭✭✭
Hi, I had the same problem. The only solution I found is to offset the face by 0mm and then replace it. It is a bad workaround, but it works.1
I found that once a derived face has a custom appearance, the right-click menu changes from "Add appearance to face" to "Edit face appearance". Once this happens, you cannot use the right-click menu to change these faces separately.
But the appearance side panel has a button that will open a new dialog to let you add a new appearance to a derived face! This solves the problem, though it was hard to find.
