How to break color derived selections
I am doing a simple copy part using transform. I need to be able to change the color of individual faces of the copied part but am running into something new. It now says the color is a “derived selection”. I can’t find any way to stop this or break the link. In the past this was not a problem so something has changed recently. Any help is much appreciated
rafael_telgmann Member Posts: 126 ✭✭✭
Hi, I had the same problem. The only solution I found is to offset the face by 0mm and then replace it. It is a bad workaround, but it works.1
