Extrude through all does not stop at the end of the part
terry_milamterry_milam Member Posts: 9
When I extrude this rounded edge with the through all option it doesn't stop at the curve but does stop about 16mm later for some reason. I can choose blind and stop it at the far edge of the curve but that leaves me with a long edge on the curve I have to trim off manually when I print this.  Any ideas?  Thanks
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 930 PRO
    Through all goes something like 500 mm.  I think you are looking for "Up to face."
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    That would be the blue box asking you to select a face.
  • terry_milamterry_milam Member Posts: 9
    Trough all works but doesn't stop at the end of the part
    Up to face doesn't extrude at all unless there is an additional setting I'm not putting in.
    Thank you so much Neil!  Figured I was just overlooking the obvious
