Extrude through all does not stop at the end of the part
terry_milam
Member Posts: 9 ✭
When I extrude this rounded edge with the through all option
it doesn't stop at the curve but does stop about 16mm later for some reason. I
can choose blind and stop it at the far edge of the curve but that leaves me
with a long edge on the curve I have to trim off manually when I print
this. Any ideas? Thanks
Matt_Shields
Member, Onshape Employees Posts: 930 PRO
Through all goes something like 500 mm. I think you are looking for "Up to face."0 -
NeilCooke
Moderator, Onshape Employees Posts: 5,979
That would be the blue box asking you to select a face.Senior Director, Technical Services, EMEA2
Up to face doesn't extrude at all unless there is an additional setting I'm not putting in.
