Fix Importing Large Files
AuroraRon
Member Posts: 138 PRO
I am experiencing constant import issues with Onshape when working with large files. Despite using Onshape for seven years, I have yet to notice any improvement in this area. I love using Onshape, but working with files that are not created in Onshape becomes very difficult or impossible. I would settle for just a shell, but parts with errors keep wrecking the complete assembly.
"Failed to import parasolid"
has been identified as a bug and we are working on it. As soon as this gets addressed and is pushed to cad.onshape.com, we will update this ticket to so you can confirm the update.
Does anyone know of a way to convert or import a Parasolid or stp file to one big solid or shell so that I can at least show something on a drawing? It's been like this for every large assembly since I started here seven years ago and still nothing from Onshape.
The demos I've tried so far have file size limitations.
After seven years of using Onshape, I still can't get any large file format to import into Onshape that is remotely usable. It does not matter who the source is. Will the importing from other formats ever be fixed?
I am currently trying to import a John Deere Engine - AH SNAP is the word of the day …. Nothing is working! How can I expect to design off-road equipment that will include several large imports, such as Hydraulic Pumps and motors, an Engine, Axles, Consoles, Seats, and other imported components? Can Onshape handle it?
This engine model is so simple compared to the JD4 I am trying to import.
I can tell you from almost ten years here, it’s an ongoing issue. What error are you having, perhaps I can help.
We have been having the same issue with aerospace composites. They will either fail the imports or take hours to import with faulty geometry. Has anyone found a work around. We are sent STEP files from our customers and it is coming mainly from CATIA
