Can I derive a Part within the same Part Studio?
Im working withing a same PartStudio. I have several parts that share the same basic geometry. However, that geometry could be modify in the future so I want all the parts to be modify if any change is made to the initial geometry.
Derive does this, but I believe it works by linking a part from one Part Studio to other Part Studio. I didn't manage to make it work within the same Part Studio.
Am I missing something? Is there maybe an option in the transform feature that i could use instead?
Thanks!
Thanks!
sebastian_glanzner Member, Developers Posts: 457 PRO
You can use the "transform" feature and choose "copy in place" as option.2 -
rick_randall Member Posts: 402 ✭✭✭
Or right click part in feature tree, choose "copy here" and it opens transform with "copy in place" already selected - ultimately the same thing, just another way to get there.
2
If you share a link, I'm sure multiple folks will chime in.
