Assembly Planes - Where are they?
It appears that planes in assemblies are not an option. I've searched this forum for answers and found discussions from several years ago, but surely there's an update to this fundamental feature, no?
4
Here are some past discussions (which you may have seen already):
On top of adding a mate connector(s) at the origin, otherwise adding a couple explicit mate connectors to your part can usually solve the problem, or inserting a layout sketch in the assembly is also a good option for more complex cases.
- hide the first MC you create (so you can select the origin for the next one!)...and
- remember to use Shift to lock to the axis you want,
- Shift+N to name each one as you create them, and if you
- remember to use Shift+Enter to save each one and keep the dialog open to make the next MC (see - this has already taken longer to type than to add them).
For me, the main hassle is the lost time when I forget to add these MCs at the beginning and use other less robust references instead...until I remember that I like the 3 MC workflow.Simon Gatrall | Staff Mechanical Engineer | Carbon, Inc.
I'd really like to see a mate connector which behaves as a full coordinate system (3 selectable axis and planes), so we don't have to add 3 of them every time. If it then would be placed at the origin as default, that would be even better.
Adding to the conversation - I would like to define a plane in my assembly that is a symmetry plane. This way I can measure the distance between anything and the symmetry plane to get the overall dimension (I have only one side detailed out).
Planes in assemblies would be much needed! I can't believe this is not an option…at least there should be the option to be able to see visible planes of parts, in assemblies, so as to be able to use them to section views…c'mon!
I believe mate connectors are essentially your assembly planes
The mating process is fine, but there needs to be some way to address the sectioning, especially when you can't use a mate connector as a "plane".
Mate Connectors can be used to create a section view. Just select the Mate Connector, and the section plane will be defined by the XY plane of the Mate Connector.
Ultimately at the least the Section creation dialog should have an option to run thru the origin aligned with XYZ with angle control.
This is the type of stuff that has our more advanced users not consider Onshape as a serious engineering tool
CAD Engineering Manager
