Permanent Dimension Display
roy_yang375roy_yang375 Member Posts: 13 PRO
In the part studio, there is a function called 'show dimensions' from a sketch. This function can temporarily display the dimensions in grey on a 3D model. I am now wondering if it is possible to have a permanent dimension display. This would involve transferring the dimensions directly to the composite part and maintaining their display on the 3D model.
Are there any existing feature scripts that can fulfill this functional need
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,859
    It is not currently possible. Please create an improvement request in the category on the right ==> or via Contact Support.
  • roy_yang375roy_yang375 Member Posts: 13 PRO
    Thank you, I've made an improvement request. I noticed that many people have similar thoughts.
