Polygon creation
shashank_aaryashashank_aarya Member Posts: 265 ✭✭✭
edited September 2015 in Using Onshape
Currently to define the number of sides for polygon we move the mouse to a direction until we get the number as shown below.
It requires some judgement to adjust the number, however I agree that it is not difficult once getting familiar with this tool. But I feel that it would be excellent if we could put numeric input just as we provide in offset.
  • jakeramsleyjakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 668 image
    If you enter the number on the keypad during creation, it should change it to be that number.
    Jake Ramsley
    @jakeramsley
    Works like a charm, even with two digit values up to 29. Thanks for the tip.
    @jakeramsley Thank you very much for the tip. Works nice!
    3dcad said:
    @jakeramsley
    Yes, after 29 there is some ambiguity as to what was entered.  We do not do one or two sided polygons so they can be used to prepend to a second keyboard stroke.
    Jake Ramsley
