Error in Onshape Course
Grav_electricGrav_electric Member Posts: 20
I was following the Introduction to Sketching course in Onshape, I was on the last part to finish section 4, Intermediate Sketching, when I was on slide 7, about the measurements, I think the measurements on the slide are false, because I have tried several ways, and come to the same spot, where all of the sketch is red. Is it me or the Course?
  • robert_scott_jr_robert_scott_jr_ Member Posts: 659 ✭✭✭
    A link to your document is needed. - Scotty
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,915 image
    If your sketch is red then you've introduced an error somewhere, likely a constraint that was automatically inferred.
  • kate_leipold_ritkate_leipold_rit Member Posts: 43 EDU
    I think this usually happens due to an accidental vertical constraint due to the top and bottom points of the arc.
