measuring distances for extrudes - beginner question.
rlbrk
Member Posts: 31 ✭
Hi, in what way I can know how to set both of the extrudes that they will be flushed and be flat surface? it doesn't seems practical to go to each one of the extrudes and do the math yourself to make the lenthg of the extrudes match to a certain point. Cant you see the measures on the extrude tab? I'm sure there is a better way than do it manually...?
https://cad.onshape.com/documents/feeafb87e93684b0f10c813b/w/ceb86e65fb96e6e9065eea91/e/dfa7935140b996002508f64b
but is there a way to measure specific area of the extrude? for example the distance for each circle from the yellow wall. my English isn't so good, hope you understand
