Attractor Pattern junction
jean_philippe_delavallade
Member Posts: 14 ✭✭
in General
Hi,
I'm trying the Attractor pattern on a solid of revolution. It's OK but the problem is that the pattern doesn't join correctly.
See the screenshot.
https://cad.onshape.com/documents/a5f5be574d6a5634babad56c/w/b224ed94db346ffded968616/e/3e37ea518e7fcf68281240a9
Thanks.
See the screenshot.
Thanks.
I vaguely remember these kinds of challenges from using Attractor Pattern in the past. Perhaps the default should be to use the full parameter space with Border=0 even if the instances will only partially be on the surface. There could also be some sort of special accommodation for periodic surfaces.
i've tried but the result is the same.
Thanks
Here's what I meant.
and yes, this hack wouldn't be necessary.
