Attractor Pattern junction
jean_philippe_delavalladejean_philippe_delavallade Member Posts: 14 ✭✭
Hi,
I'm trying the Attractor pattern on a solid of revolution. It's OK but the problem is that the pattern doesn't join correctly.
See the screenshot.
https://cad.onshape.com/documents/a5f5be574d6a5634babad56c/w/b224ed94db346ffded968616/e/3e37ea518e7fcf68281240a9
Thanks.
  • S1monS1mon Member Posts: 4,054 PRO
    @Evan_Reese
    I played with this a bit, and I can't easily tweak the parameters to solve the issue either. I suspect that I could hack it by dividing up the revolved bottle shape into a wedge and tweaking the angles until I could get something that would pattern nicely.
    I vaguely remember these kinds of challenges from using Attractor Pattern in the past. Perhaps the default should be to use the full parameter space with Border=0 even if the instances will only partially be on the surface. There could also be some sort of special accommodation for periodic surfaces.
  • jean_philippe_delavalladejean_philippe_delavallade Member Posts: 14 ✭✭
    "dividing up the revolved bottle shape into a wedge and tweaking the angles until I could get something that would pattern nicely"
    i've tried but the result is the same.
    Thanks
    edited June 2024
    @jean_philippe_de
    Here's what I meant.
    The trick is that I split the surface, and tweaked the 7.4 degree angle until the instances visually lined up with one 1/4 of the whole.
    Ideally this hack wouldn't be necessary. It would also be tricky to get this to be exact and parametric.
    Thanks !!
    and yes, this hack wouldn't be necessary.
    This issue is on my backlog of things to fix with this feature, but I can't guarantee a timeframe for it. My priorities are elsewhere at the moment. What it needs is a way to tell when the base surface is periodic in the u or v direction, then update the grid accordingly.
    OK and thanks Evan.
