Not able to log in
Marinus_LurzMarinus_Lurz Member Posts: 1 PRO
Hi Team,
I received the "Congratulations! You've been promoted to Professional user." email, but I can't log in. I work at SpinMaster and am part of the enterprise subscription. I previously had a soft user license and now have a Professional license.
When I try to log in, the SSO channel still shows the soft user license. Using my email and password results in an "invalid email/password" error. Additionally, I can't reset my password as the system doesn't recognize my email, despite receiving the promotion email at the same address.
Lastly, when I click "check it out" in the promotion email, I see my email with the Professional license. However, signing into OnShape via SSO still shows the soft license.
Please assist.
  • mfalkensteinermfalkensteiner Member, Onshape Employees, csevp Posts: 87 image
    Please email support@onshape.com
    Principal Technical Services Engineer, EMEAI
    If you are on Enterprise plan, use the URL "yourcompany.onshape.com" and not cad.onshape.com for trying to Sign-in using SSO
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    edited June 2024
    @Marinus_Lurz The email is simply showing Professional in the forum. In the Forum we do not separate ENT, PRO or Standard.  They are all "PRO" in the forum.  I might consider having it show `PAID` or something similar.
    If you want to get into the forum, I would suggest signing into Onshape first then use the ? menu -> Forum to get there.  We can pull a ticket from here if we need to.
