Constant plane via mate connector (FS)
ben_partouchben_partouch Member, csevp Posts: 158 PRO
Hello,
How do I establish a plane using a mate connector, in a way that no matter how I orient the part, the directions will remain the same.
The plane will be used for a sketch and then extrude the sketch normal to the sketch region.
Thank you
  • Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 224 image
    edited July 2024
    Either:
    1. Construct a mate connector from selections in the feature. You need a point for the origin and two directions orthogonal to each other.
    2. Place a mate connector on the part being derived. If you move it after it is derived, you'd need to construct a query to transform the mate connector and the part.
    Without explicit definition, you will be subjected to the right and left-handedness of edge direction (+Z direction) and implicit direction guesses when transformed in world space that will affect clocking (XY plane orientation about the Z).
    Support & QA
  • ben_partouchben_partouch Member, csevp Posts: 158 PRO
    The feature is creating new geometry in this case, so I assume opt 1 is preferable.
    I can't figure out how to make a plane that is parallel to the Z normal direction. Only xy planes.
    Thank you Jason.
  • jelte_steur_infojelte_steur_info Member Posts: 603 PRO
    would this work?
    plane(coordsystem.origin, coordsystem.xAxis, yAxis(coordsystem));
    //this would be normal to yaxis. swap the last two arguments to let the x axis be normal. either optionare parralel to Z.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,926 image
    It's not clear what you are trying to do? I don't follow Jason's comments either.
    If you just want to convert a MC to a plane, use evPlane
    Thank you @jelte_steur814, I'll definitely try this.
    @NeilCooke- Using evPlan with the MC only works in one orientation. As soon as the parts move the whole thing is messed up.
    I want it constant and robust at all orientations.
    @jelte_steur814
    can't get it normal to Z.
    Tried both ways.
    @jelte_steur814
    I got it. zAxis...
    Thank you!
    Let's see if the rest works well.
    How do I set a vector for a transform operation that is following the new coor' system?
    So if I want to move 50mm only in the Y axis.
    Thank you
    i think something like this?
    i didn't test any of this, but you get the gist I hope.
    const direction = evAxis(yAxis).direction;
    const translationVector = direction * (50 * millimeter);
    It was close. Finally got it though.
    Here's the solution:
    var yDirection = yAxis(location2);
     var line1 = line(location1, yDirection);
                debug(context, line1, DebugColor.MAGENTA);
                const translationVector = yDirection * secRowDis;
                // debug(context, direction, DebugColor.RED);
                opPattern(context, id + "patternC", {
                            "entities" : qCreatedBy(id + "boolean2", EntityType.FACE),
                            "transforms" : [transform(translationVector)],
                            "instanceNames" : ["secondraw"]
    Thanks so much @jelte_steur814
