Onshape keeps disconnecting
grey_harris
Member Posts: 7 ✭
Hello, just lately onshape keeps disconnecting and then reconnects. I have never had this problem before it just started. It says "onshape is not connected your document is saved attempting to reconnect". It does it quite often maybe every 10 to 15 minutes. Thank you for your help.
NeilCooke
Moderator, Onshape Employees Posts: 5,926
It all points to your internet connection. If it drops momentarily, Onshape will disconnect. Try tethering to your mobile to troubleshoot or jump on another wifi.Senior Director, Technical Services, EMEA0
Could you be switching networks? Like between a wired and a WiFi connection? This can also cause Onshape disconnects.
What did they change?
