Javascript problem
john_wilkes
                    Member Posts: 2 ✭
                    Hi,
When I try and open a part studio, the message 'Log4javascript_uncompressed.js:621" appears, and the screen is unresponsive - or at least I can't select a sketch plane to get started.
System is XP and browser is Firefox - WebGL is force enabled in Firefox.
Any ideas?
Thanks,
John
Any ideas?
Thanks,
John
lougallo
                            Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
                    @john_wilkes the issue is XP. Although you may be able to run the more current browsers, the operating system is not going to be able to run WebGL well. You will need to be on Windows 7 or later to support WebGL properly in the browser. That is not to say once that requirement is met, the hardware you have can support hardware acceleration for good web gl performance. Use the ? Menu -> feedback to send us any other issues you may be having.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
