How can I list all documents created and ALL part numbers assigned?
Otto_DeRuntzOtto_DeRuntz Member Posts: 24 PRO
I've just started using Onshape, moving from Creo & Windchill. I am lost as to how many documents I've created, how many part numbers have been assigned.
Little by little I am importing assemblies, many use many of the same parts and I need to keep track of what parts have been imported and assigned part numbers and where they reside.
Is it possible to get a 'global' list of all documents and associated properties?
  • Caden_ArmstrongCaden_Armstrong Member Posts: 307 PRO
    As far as I know, you'd have to use the API to get all the documents, part numbers and metadata.
    www.smartbenchsoftware.com --- fs.place --- Renaissance
  • S1monS1mon Member Posts: 3,499 PRO
    If the parts/assemblies/drawings have been released, then there is a list view of all the released items, but will not look beyond the current folder. This doesn't include all the properties. Right now you'd probably need/want a PLM system to see all that info.
    BTW, here's an improvement request to make it so list view will cover everything without digging through each folder one at a time. It won't list things that aren't released (that could be another IR).
  • Otto_DeRuntzOtto_DeRuntz Member Posts: 24 PRO
    edited July 2024
    Thanks for the feedback!
    I started to reply with questions more related to Release Management, so I removed my comment and move it to a topic on Release Management.
