FeatureScript editing logic function
graham_lockgraham_lock Member Posts: 265 PRO
Hi,
I've found the documentation for the Editing Logic function but I can't see how to actually link it to the feature?
Any example appreciated.
  • MichaelPascoeMichaelPascoe Member Posts: 2,803 PRO
    Here is an example of how to use it: Editing logic example
    RENDERCAD
  • graham_lockgraham_lock Member Posts: 265 PRO
    Thank you but I get an error message of document doesn't exist or I don't have permissions?
    edited July 2024
    There you go, it's set to public now.
    Also here is more explaining how edit logic works: edit logic forum post
    RENDERCAD
  • jnewth_onshapejnewth_onshape Member, Onshape Employees Posts: 89 image
    edited July 2024
    I've listed this from frame.fs (forgive the formatting, I dont write the forum software we use):
    * Create frames from a profile and set of path selections.
    annotation {
    "Feature Type Name" : "Frame",
    "Manipulator Change Function" : "frameManipulators",
    "Filter Selector" : "allparts",
    "Editing Logic Function" : "frameEditLogicFunction"
    export const frame = defineFeature(function(context is Context, id is Id, definition is map)
    The annotation that precedes the function code specifies a bunch of useful bits. This is how we tell the function what manipulator function to use and what editing logic function to use.
    Fantastic thank you.
    The link to edit logic forum post points to the sample document?
    RENDERCAD
    Thank you!
