How do I make a "fillet" in a sketch based on vertex from imported stl
NeilCooke
Moderator, Onshape Employees Posts: 5,970
A fillet by definition is an arc - an STL file is faceted, so trying to create a curve that follows "random" faceting is not a good idea. If the arc won't snap, try adding a coincident constraint afterwards.Senior Director, Technical Services, EMEA1
That's kinda working but I need to adjust it manually to get a perfect curve that's line up, but I'm wondering if there's an other way to do that.
With a 3 point arc, I can't make the edge snap into the point that I marked on a vertex, and it creates a small gap.
