Is it possible to apply curvature limits to splines?
in General
Hello,
I am currently in the thralls of cable management (oh joy) on my assembly and am using 3D splines to connect various endpoints and sweeping along them to generate cables.
One thing I'm struggling with is sometimes the splines bend quite tightly which would be an unrealistic bend for the cables/tubes/hoses. I'd like to apply some kind of limit on the curvature radius of the spline but don't see an option for this. Is this possible through splines? Is it possible through a different avenue?
I can add additional points for the spline to follow but setting up the planes and sketches is time consuming and difficult to adjust once made.
https://forum.onshape.com/discussion/18756/custom-feature-cable-wire-routing
